How do I replace Hinges on HP Chromebook x360, model 14a-ca0036nr
I want to confirm the required screen hinge part number for an HP Chromebook 360, 14a-ca0036nr. I was looking for a video or tutorial on to replace the hinges. If I can't find one, I may try to post a video when I try this Hinge replacement on a HP Chromebook x360, model 14a-ca0036nr.
Add a comment
1 Answer
Most Helpful Answer
Hi @brenick19097
Here's the maintenance and service guide for the HP Chromebook x360 14a-ca0000 series, that should be applicable to your model as well.
Go to p.37 to view the procedure to remove/replace the display assembly. This will allow you to see how to remove the hinges.
The hinge part number (see Item #11 on p.15) is M15311-001. Search online for the part number only to find suppliers that suit you best. Just to verify the part number, it is the same number as shown in the parts list for your exact model.
Score 1
Add a comment
Add your answer
brenick will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 16
All Time: 60
