Repair and disassembly information for the 2020 refresh of the MacBook Air model A2179 with an Intel processor that was released in March 2020.
104 Questions View all
Not charging, anyway to charge the battery with a external charger?
Hi, so my MBA intel 2020 isn't charging anymore. It was working fine when plugged in but we recently had a power outage and the battery dropped to 0 percent. Not it's super slow when plugged in. I tried several power adapters so that's not it. 2 questions. What's wrong with my macbook?
Also is there anyway to charge the battery externally? If I can get a little charge on it my macbook should work again when plugged in. Any advice is appreciated! Thanks!
Add a comment
1 Answer
Reset the SMC.
Before trying anything else, the SMC controls the power system on a Mac, and you may need to reset it. If your SMC is faulty, your Mac will experience power issues. I also would suggest running Apple Diagnostics. This way you could see where your Mac is having problems.
As far as charging the battery externally, I don't believe that is possible. That is, I have never heard of anyone doing that. If your Mac is slow, this is because it is trying to lower the processes in order to send power to the battery. Instead of running solely on the power adapter, it is trying to still use battery power.
If possible, try to download the Coconut Battery app. There it will tell you if your battery is having problems.
Worst case, the battery may be faulty, and you will need to replace it.
Add a comment
Add your answer
JNY CAT will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 16
All Time: 68
