Televisions made by the Chinese multinational electronics company, TCL.
267 Questions View all
I can see the TCL start screen for a split second
Jeesh.... Im sitting here with a 65" 65S4 TCL. 4k. Only thing is I DONT see any backlight when I shine a light on a dark spot for a minute. But when I turn on, I can see the TCL start screen for a split second then it goes away. Not sure what to do. My TV is on the floor upside down with the back-off.
I was thinking about replacing the battery. But now I think about it that makes ZERO sense considering it works and turns on and everything lol. So I'll buy new lights uhhhhhg....
BTW, I bought a Black Friday deal on a Samsung 4k UHD Crystal 65" on sale for $400 from $900. HIGHLY recommend this one as the difference in picture quality is night and day.
I'm gunna go to BBB as well as the other person. Bc they r right- this is rediculous. We never have these long and they just DIE! These r sooooo expensive man! Come on u can do better TCL!!
Add a comment
@tysalminen I am a bit confused by this:"Only thing is I DONT see any backlight when I shine a light on a dark spot for a minute". You can't see the backlight but should see the screen ie. Splashscreen, Menu or whatever else your screen should display. This" the TCL start screen for a split second" is usually a pretty good indication that it is your backlight array that has failed. If you can't see any shapes, silhouettes etc. then it is possible that this is a main board (worst case scenario a panel issue). Remove the back cover from your TV and post a picture of all of your boards. Arm yourself with a multimeter and let's figure out where we can measure the voltages for your back lights as well as the voltages controlled by your main board.
Adding images to an existing question
Add a comment
I had a 55” TCL break 3 years ago. Can’t believe 3 years later & I see the same complaints…
I could see very faint shadows on my screen. You don’t have to be in a completely dark room to see this. But you def won't see it in a sunlit room. I don’t have a volt meter nor know how to read one. I am good w/replacing hardware/electronics. I took an educated guess that my problem was the cheap LED backlight strips. Fixed it & 3 years later this month and my tv is still running! Here is my long story - may not work to everyone. Good luck!
The sound is working but The screen is black.
Add a comment
Add your answer
Ty Salminen will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 15
Past 30 Days: 42
All Time: 119
