Won’t stop filling with water on all cycles
Having issues with a kenmore 110-20022013 series washer. Won’t stop filling with water on all load sizes and cycles. Would it in the sensor that has gone bad?
It could be the Washer Water-Level Pressure Switch (part # W10268911) in the control panel but it could also be a blocked, split or loose water pressure level hose (part #WP353244) between the switch and the bottom of the tub.
Here's a video that may help. If either part is faulty and needs to be replaced, search online for the part number only to find suppliers that suit you best.
Here's the tech sheet if you need to run the diagnostic tests that may also help.
Past 24 Hours: 4
Past 7 Days: 4
Past 30 Days: 6
All Time: 24
