Released October 26, 2018. Models A1984, A2105, A2106, A2108. Available as GSM or CDMA / eSIM, nano-SIM or dual-SIM / 64, 128, or 256 GB / Black, White, Blue, Yellow, Coral, or Red. (Pronounced "iPhone 10 R.")
474 Questions View all
The screen does not work properly when I put down the screen
I have got an issue with Iphone xr. I replaced the screen and tested it before I put the screen down to the frame.
Everything worked fine. But when I put the screen back to the phone, touch did not work and sometimes had partial dim backlight. I tried a couple of screens with the phone and found it they work all the same.
I had to cut one of the little things on the bottom of lcds which the screw passes through to get the screen sit properly because there was one pentalobe stripped.
Has anyone been through this issue before or know how to fix?
Add a comment
1 Answer
Which screen are you using to replace the old one. If its an off brand one that could be the problem. People sell cheap LCDs that most of the time dont work and are crappy. Make sure you have a good one, if you dont then you should replace it.
1 Comment:
Thanks for the answer. I am quite sure I am using reliable LCDs as I have not got the issue with other XRs before.
by
Add a comment
Add your answer
Jake will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 12
All Time: 33
