A more affordable, purely handheld version of the Nintendo Switch game console, with integrated Joy-Con controllers and a slightly smaller screen. Released September 20, 2019.
178 Questions View all
How do I tell if the battery is receiving charge current,
Nin. Sw. Lite is not responding to charging. I have the back shield off, is there a set of contacts to the battery that I can monitor with a DVM - to see if when the charger is attached and powered that the voltage is higher than w/o the charger attached.
1 Comment
@jgbsr I assume that you are referring to a Nintendo Switch Lite
by
Add a comment
1 Answer
Most Helpful Answer
@jgbsr yes you can. Follow this guide Nintendo Switch Lite Battery Replacement - iFixit Repair Guide right to step 10. do not remove any cables etc. Now get a multimeter and place it on something like a 30 VDC range. Place the red probe on the red contact of the battery connector and the black on the black contact.
Measure the voltage with your Switch plugged in and with it not plugged in. You will see a higher voltage with it plugged in. If the voltage does not change. You are having issues with the charging circuitry/charger.
Score 1
Add a comment
Add your answer
JGBSR will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 5
Past 30 Days: 13
All Time: 44
