Repair and installation information for light bulbs and fixtures.
153 Questions View all
Why are my lights not working on my ceiling fan
The lights on my ceiling fan in my living room went out yesterday, the light bulbs that go in it was different than I’m use to seeing and I had to order new ones on Amazon. I tried to take the bulbs out of the fixture in the kitchen to put in the one in the living room until the new bulbs arrived. When I did this the lights still didn’t work. So then I thought, hmm I wonder if the bulbs that were in it weren’t bad so I tried those (bulbs that were originally in the living room) in the fixture in the kitchen. I put them in and they blinked on for a second then went out. Now neither of them are working. I got the new bulbs in the mail today and still nothing. The fans on both work but neither of the lights will come on. What can my problem be?
Update (11/01/23)
When I put the old bulbs into the light fixture in the kitchen one bulb blinked on and then immediately went back out.here is what the bulbs look like, I’m not quite sure what type of fixture they are, they were already in the house when we bought it last year. How would I know if it’s the control circuit as you stated and what is the solution for that?
Score 1
Add a comment
1 Answer
I'm guessing because you haven't supplied enough info. - like what type bulb and fan? Did they ALL blink on in the other fan?
The bulbs that were in there (at least one) was defective and when you put it into the other fan it burned out the control circuit in that fan also. That is assuming they were LED bulbs. If not CFLs and incandescent should be wired directly so they don't have a control circuit to burn out. Then I have no idea.
2 Comments:
Thank you for your response. I added a picture of what the bulbs look like if that helps. I’m not sure exactly the type. When I put the old bulbs into the fixture in the kitchen one bulb blinked and immediately went back out.
by
those appear to be std CFL bulbs, so the should not be any control circuitry in the fixture. Therefore, I have no idea why you have this issue other than a bulb issue. Are they the right voltage?
by
Add a comment
Add your answer
Misspriss1604 will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 15
All Time: 56
