Repair guides and support for laptops manufactured by MSI.
274 Questions View all
Where can I get a replacement LCD display for a MSI Z16 Creator Laptop
I have MSI Z16 Creator a11uet laptop where the digitizer is cracked, not sure if it can replace separate, I haven't had much luck finding a replacement, does anyone know where to get one or a good site that sales LCD displays? I have tried allexpress and ebay.
Add a comment
1 Answer
Most Helpful Answer
Hi @andy45292,
Best option may be to disassemble the laptop and remove the LCD panel.
Not sure with MSI but with others e.g. Asus, HP, Lenovo there's usually a part number somewhere on the back of the panel either on a sticker or printed on it.
Don't confuse the part number with the screen manufacturer's make and model number which may also be onthe back of the panel. Although sometimes knowing that can be helpful as well when looking for a replacement. (LCD screens are usually made by specialist manufacturers and not by the manufacturer of the laptop).
If there is a part number, search online for the part number only as the screen may be also used in other models but may not be listed with a supplier as being compatible with your model even though it is.
Just what I'd do
Score 2
1 Comment:
Thanks for your input on checking the LCD panel model instead.
by
Add a comment
Add your answer
Andy will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 15
All Time: 85
