Released September 20, Apple's largest and most expensive 2019 smartphone features a 6.5" OLED display, a triple-lens camera system, and greatly improved battery life. Successor to the iPhone XS Max.
165 Questions View all
Battery disconnects after dropping by mistake.
I got my battery replaced from an third party vendor for apple and the cowlings are missing after the same, because of which the battery shuts down instantly and is not turned on unless I get the battery in place with help of a insulated tape. Is there a permanent solution for this?
Add a comment
Most Helpful Answer
When placing battery connector back onto the board does it pop off right away or does it stay clipped in? (If it pops out right away then the connector maybe damaged. If it stays in then I would look into possibly purchasing brackets online or seeing if repair shop would resolve issue.
Score 1
Add a comment
I agree with Edward, that sounds like it could be a connector issue. First off, you can buy specifically-made adhesive strips for your battery here, and replacement display adhesive here. And if that doesn't work, I recommend that you try replacing the battery yourself. You can get a replacement here.
iPhone 11 Pro Max Battery Image
Product
$34.99
iPhone 11 Pro Max Battery Adhesive Strips Image
Product
$3.99
iPhone 11 Pro Max Display Assembly Adhesive Image
Product
Score 1
Add a comment
If you look around online you can find a replacement for that little bracket that holds the battery connector on. Here's one example I found after a quick search; you can probably find more if you look a little harder.
Apple iPhone 11 Pro - Metal Cover Battery Connectors
You can frequently find it being sold in a bundle as "small parts" on places like eBay and AliExpress as well.
Score 1
Add a comment
Add your answer
Vigneshwar H will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 16
All Time: 55
