Repair guides and support for top and front loading Whirlpool brand washers.
426 Questions View all
Why is my impeller not spinning during wash cycle?
My washing machine impeller is not spinning or agitating clothes during wash cycle, splines are intact under impeller. Washer works perfect but for the impeller. What is the problem?
2 Comments
Hi @nateberg,
What is the model number of the washer?
by
WTW5600XW3 Here is the model#
by
Add a comment
Most Helpful Answer
Hi @nateberg
Here's the tech sheet for the washer.
Run the diagnostics as shown on p.2 and check if any error codes are displayed. There's a chart on p.3 that shows how to interpret the status LEDs to know what code it is.
Just wondering if it is a shifter problem (possible error code F7 E5) or perhaps a basket speed fault (F7 E1)
The error codes description and possible fault causes are described on p.6→p.7 of the sheet.
If you find the problem and it is a faulty component here's a parts supplier that is useful.
Scroll through the parts diagrams to find the faulty part and then once found it will show the manufacturer's part number for the part. Search online using the part number only to find suppliers that suit you best.
Score 1
1 Comment:
I will try these tests and get back to you. Thanks
by
Add a comment
May be the impeller shaft splines damaged.
1 Comment:
All the splines look good
by
Add a comment
Add your answer
Nate Berg will be eternally grateful.
Past 24 Hours: 3
Past 7 Days: 15
Past 30 Days: 33
All Time: 183
