0
Score
Avatar
Steve Cox
Asked
Flashing Orange light on Power-Up
History
Hi, Can anybody suggest an alternative remedy. I replaced the hard drive on my 1st gen Apple TV as I was told it would almost certainly the hard drive. After ordering one and fitting it, I still have the orange flashing light.!!!
Any other ideas what it might be ?
Edited by: machead3 ( )
Post Answer
0
Score
Avatar
machead3
21.3k
Answered
PermalinkHistory
1. unplug unit
2. after 1 minute plug back in and hold the menu and button for 3 seconds.
(unit should reboot and go into recovery mode)
3. In recovery mode, run diagnostics and if passed then perform factory resotre.
4. Problem should be resolved - resync with iTunes, run updates
If this Answer is helpful please remember to return and mark it Accepted.
Thanks Machead3. I've tried that but it is still flashing orange.
Steve Cox,
Two reported causes: - failed apple update, failed logic board. You know if you did the update. . . if you can put the HD in an external case or different machine you might be able to wipe the drive and start over. Good Luck,
machead3,
Add Your Answer
