Released in November 2020, the 13" MacBook Pro features Apple's Arm-based M1 SoC with both an 8-core CPU and 8-core GPU. (Model A2338 / EMC 3578 with two Thunderbolt 3 ports)
115 Questions View all
How to fix Touchbar that works but doesn't light up?
My 2020 Macbook Pro 13 M1 has a working Touchbar buttons but the screen is completely black. I don't know what happened to it because it is used. How can I fix this? All of the information I have found online is for the older Intel Macbook Pros. Has anyone figured out how to fix this on Macbook Pro M1?
Add a comment
1 Answer
Here’s the Apple service manual for your system 13” MacBook Pro (M1, 2020) I would inspect the ribbon cables from the the TouchBar refer to page 78 see if reseating them resolves things. Do make sure you review our guide MacBook Pro 13" Two Thunderbolt Ports Late 2020 Battery Replacement to Step 14 disconnecting the battery before you move things.
If that fails fix the issue and you don’t see any liquid damage, the panel is likely cracked. Apple only sells the full upper case assembly which is quite expensive!
Add a comment
Add your answer
Katies Pixels will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 5
All Time: 44
