Power stereeng not working
Check the fuse located under the dash for your electronic power steering module. If it's okay, then check the harnesses for the module itself for bad connections or corrosion on the terminals. If there are no bad connections, you'll have replace the EPS module itself more than likely.
Past 24 Hours: 0
Past 7 Days: 9
Past 30 Days: 19
All Time: 47
