The right ear started cutting out, is it fixable?
The sound in the right ear started to cut out, it would work only in a certain position. It's pretty much complete cut out now, but i do really like this headphones and would much rather fix it!
Add a comment
1 Answer
@madssaucexx since there is no good teardown yet, take a look at this video to work on your headphones. You will have to modify it to suit your need. Then check your wires from the circuit boards to the drivers (speaker). You may have a broken wire or a bad solder issue. If you get it apart, and you can see the wires, post some pictures of what you got going on with it. That way we can see what you do. Adding images to an existing question
While you work on your headphones, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has the same problem as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Repair is War on Entropy!
Add a comment
Add your answer
Mads Saucexx will be eternally grateful.
Past 24 Hours: 6
Past 7 Days: 13
Past 30 Days: 44
All Time: 376
