Change A10s charging port
Can i change my A10s charging port (micro usb) to type c port.
The short answer is no you can't.
The charge port board and the USB controller on the systemboard in the phone are designed to work with USB 2.0 type connectors and the USB 2.0 signalling protocol and cannot handle the extra functions provided by the USB-C port.
In USB 2.0 only 4 wires are used, in USB-C it could be 4, 6, 12 or even 24 wires
Inserting a USB-C type port connector would also mean you would have to cut and widen the opening in the case where the existing USB port is located so that it would physically fit.
If you want to have a phone with the features provided by having a USB-C port, then you need to get a phone that has already has one as part of its design.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 6
All Time: 44
1 Comment
With damaging back cover and circuit board
by Janaka Priyadarshana
