Larger version of the Nintendo DSi, released March 2010 in North America. Most repairs are accomplished with only a screwdriver and prying tools.
157 Questions View all
My bottom screen keeps scrolling to the side.
Anytime I try to use my dsi, it's like I'm pressing down on the right d-pad button. I've bought a new rubber pad, as well as a new d-pad board. I installed both of them, it worked for about a week, and now the problem popped up again. What could the problem be? Could it be something in the motherboard? Thank you in advance!!! :D (I would also like to add that there's no problem with the screen, I've done multiple tests, and it works perfectly fine)
Score 1
Add a comment
1 Answer
It could be something with the motherboard, or just an unlucky replacement d-pad board. You can double check the connectors to make sure they're not loose or broken.
3 Comments:
Thanks for a quick response! I disconnected the orange strip (not sure what it's called exactly) from both the pad, as well as the motherboard. It worked for a minute, but now the same problem returned. Would you happen to have any other possible solutions?
by
@travhuber10 try cleaning the connections with isopropyl alcohol
by
I'll try that! thank you!
by
Add a comment
Add your answer
travhuber10 will be eternally grateful.
Past 24 Hours: 4
Past 7 Days: 6
Past 30 Days: 7
All Time: 29
