EZ debeg red on CPU
I installed a new m.2 drive and 4 new sticks of ram into my pc, now when u try turn it on my motherboard has a red light on the CPU ez debug, could one of the new parts caused this?
YES.
However, other things can also cause it.
parts not seated properly
connectors jarred loose or not reconnected
if the OS was on the old M2, did you reinstall it?
Is the RAM the correct type?
Does the BIOS configuration match the RAM specs?
Start by checking your BIOS. If you can't get to it, remove everything and replace your old parts. If it works, change your RAM out. If it works change your M2.
Process of elimination troubleshooting.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 6
All Time: 28
Hi @freddiescrase,
What is the make and model number of the motherboard?
What type of new memory did you install? Did you check that it was supported (compatible with) by the motherboard?
by jayeff
