The K-Mini is a compact and functional coffeemaker manufactured by Keurig.
11 Questions View all
water reservoir supply line has pin hole
K-mini is leaking water i found pin hole in the supply line from the reservoir the easiest repair would be to cut it and use a coupling but I'm clueless as to it size or if replacement would be a better but not easier option
Add a comment
1 Answer
Two things I would recommend are to take the hose off and take it to a hardware store to see which tubing would fit as a replacement or get the tubing off of eBay. Here's a link to some replacement hoses: https://www.ebay.com/itm/304995886425?mk...
Hope this helped!
Add a comment
Add your answer
techranger59 will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 11
Past 30 Days: 15
All Time: 57
