Repair guides and disassembly information for the MacBook Pro 16'' released in November of 2019. Model A2141, EMC 3347.
211 Questions View all
Everything dead, Caps Lock’s Light On
My macbook just got water damaged today, smoke burnt through the USB-C port and fizzing noises came out, so im sure the computer is dead. But the caps lock light is somehow on. Is this normal or what?
Add a comment
1 Answer
Since you're getting a caps lock then the computer is most likely still on and if you press the shift key and volume up or down you will get a volume sound meaning its still on. You probably have a damaged display or possibly a damaged backlight circuit on the motherboard. Your usb-c ports are probably going to need replacing too. I would stop using it and take it somewhere to disconnect the battery ASAP since this can get worse and possibly fry the motherboard if left in that condition. A shop that can repair motherboards will most likely be able to fix the liquid damage on the motherboard and a bad backlight circuit. If the screen is damaged then unfortunately there's nothing you can do other than replace the display.
Add a comment
Add your answer
Yehia Abdelkawy will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 4
Past 30 Days: 11
All Time: 46
