The Kenmore 110 Series is an easy to use home Washing machine created by Kenmore.
498 Questions View all
My Kenmore 110 washer will only fill under the rinse and spin setting.
My Kenmore washer will not fill. It does fill on rinse and spin setting, which I tried after watching a YouTube video. My understanding from the video was that this meant it was either a timer or temperature switch. But the video didn't line up with my washer, it was for an older type of unit. I've been trying to figure it out by looking at YouTube videos but to no avail so far. Any advice is appreciated. Thanks
Update (08/29/23)
Model number is 110.22352511.
Score 1
Add a comment
1 Answer
Chosen Solution
Hi @ericwillia96978
Wonder if it is a problem with the hot water supply or the hot water inlet solenoid in the washer.
Hot and cold water can be used for the wash cycle but cold water only is used for the rinse cycles
Check that the hot water supply to the machine is 120°F (49°C).
If the hot water supply temperature is OK here's the tech sheet for the washer.
Run the diagnostic tests as shown on p.4 (see Automatic test mode) and check if any error codes are being displayed.
See the Fault/Error Code Display Method chart on p.3 for how to interpret the status LEDs if any codes are shown.
The meaning of the code and the possible causes are shown on p.6-p.7
Score 2
Add a comment
Add your answer
Eric Williams will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 10
Past 30 Days: 17
All Time: 88
