Find repair and additional information for the LG Refrigerator LSC27910, a 2008 side-by-side model with an ice dispenser and an anti-sweat heater switch. This page covers information for model numbers matching the pattern LSC27910**.
1 Questions View all
What part is causing my fridge to trip breaker as soon as I plug it in
So my fridge LSC27910ST
instantly trips breaker when plugged in. I discovered if I unplugged the defrost thermistor inside the freezer that the fridge will run again. Figuring a bad thermistor, but I am getting the normal expected resistance readings when I test the thermistor. But if I plug it back in, the fridge shorts the breaker instantly. What related part would cause this to trip? The heater element also has normal resistance readings. Is it the board? If so, can the board be repaired?
Add a comment
Chosen Solution
So, it was the defrost heater. Unplugging the thermistor sensor essentially “unplugs” the heater, so I was confused. After putting in the new coil, everything is working fine.
Add a comment
Hi @johnrodi
Have you checked the fuse in the plug of the fridge as a faulty fuse can sometimes trip the breaker
1 Comment:
Can’t be that as my fridge is working right now with the defrost thermistor harness unplugged.
by
Add a comment
Add your answer
John Rodi will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 7
Past 30 Days: 15
All Time: 70
