Released September 20, Apple's flagship 2019 smartphone features a 5.8" OLED display, a triple-lens rear camera, and greatly improved battery life. Successor to the iPhone XS.
156 Questions View all
Cornice schermo scollata / detached screen bezel
Per togliere lo schermo si è scollata la cornice metallica che lo tiene al telefono. Apparentemente non c'è niente di rotto ma lo schermo non si accende più, avete suggerimenti? Grazie.
To remove the screen, the metal frame that holds it to the phone was unglued. Apparently there is nothing broken but the screen does not turn on anymore, do you have any suggestions? Thank you.
Score 1
Add a comment
1 Answer
Most Helpful Answer
I wouldn't think that removing the frame would cause the screen to fail, but along the bottom of the screen are delicate electronic circuits that I'm guessing the frame was protecting. I suspect that in the process of separating the frame from the screen, some of those circuits got damaged. About all you can do at this point is replace the screen and hope that's the problem.
Of course you checked the connectors carefully with a magnifying glass and a bright light for any bent or broken pins, correct? And looked at the flex cable for any tears or damage? Wouldn't hurt to clean both sides of all the connectors with 90% or higher concentration isopropyl (rubbing) alcohol and recheck.
Score 2
1 Comment:
Thanks for your reply, the phone works fine with a new screen. But I'd like to recover the original. I don't see any circuitry under the bezel though. I thought it could be a silver glue weld that holds the frame glued to the screen, on the right side that has come unstuck. I ordered the specific glue, as soon as it arrives I will try. Thanks for collaboration.
by
Add a comment
Add your answer
olleto49 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 9
All Time: 71
