Repair and disassembly information for Google's Pixel 6 smartphone, released in October 2021. Identified by model number GB7N6 and G9S9B16.
50 Questions View all
Temporary connecting PIxel 7 display to Pixel 6?
My Pixel 6 display is dead. I wonder if it is possible to connect Pixel 7 display temporarily?
I don't care about display size as I only need it for a temporary use - just want to configure debugging.
I've seen a similar question regarding Pixel 7 pro, but there were no an answer.
==== UPDATE
There is a hope that display connectors for Pixel 6 and Pixel 7 are the same. Attaching the image created from images used in display repair manuals here.
Add a comment
1 Answer
Unfortunately, chances are that either the connectors or the pinouts are different, you might have to get a cheap cracked display just to test with, if you can find one online on sites like ebay. @digitalair
2 Comments:
Added image in the Question update
by
@digitalair Ah ok then you have a bit more of a hope, i've tried to find a pinout for the pixel 6 display connector but unfortunately came up empty, the best advice i can give is to try it and find out, worst case scenario it could kill the display or the board, though.
by
Add a comment
Add your answer
Digital Air will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 12
All Time: 41
