0
Score
Avatar
Brad
25
Asked
No sound during calls, chipped logic board
History
Dropped my iPhone 4, replaced the screen. Works fine apart from when making phone calls I can't be heard or hear with earpiece speaker phone Bluetooth headset or headphones. Sound works perfect for camera Skype and voice memos. I have tried everything, and i mean everything and now i am debating whether it is the fact that my logic board is chipped, seen in the picture. Can somebody tell me what the component is at that place where it is chipped and whether you think it may be the culprit. If so is there anything I can do? I am desperate!
Update
Nobody?
Edited by: James Pearson ( ) , Brad ( )
Post Answer
0
Score
Avatar
crackmama
Answered
PermalinkHistory
hello! the new ios is out now (5.1)
but i cant do an update because i need the jailbreak, could you please try that, so that we can see if the issue is because of the software?
(I have the same sound problem)
This answer was originally to another question.
Just updating now, i am sceptical about it working as i tried it on the 5.1 beta's and it never worked :/ But lets hope! I'll update soon!
Brad,
Did not work for me :(
Brad,
0
Score
Avatar
Jason Estep
Answered
PermalinkHistory
Try going to settings and then sounds, then turn the volume all the way down with the slide bar after that turn it back up, sounds strange but has worked for me on multiple occassions!!
Thanks Jason I will try that!!
Brad,
0
Score
Avatar
Tam Nguyen
61
Answered
PermalinkHistory
you have a faulty screen, I had the same problem when i purchased a cheap one on eBay. I could not get any sound during calls and the other person could not hear me either. I put the old cracked screen and everything worked fine. I complained to the seller and got a refund, I brought another one which was a bit more expensive but it worked fine.
its a hit and miss i have found with aftermarket LCD/Digitizer screens some suppliers are cheap but somewhere in the manufacturing process something got screwed up, other times its good.
0
Score
Avatar
Will M
Answered
PermalinkHistory
take a pair of headphones and plug them in to the jack. Make a test call. If you hear audio and can hear the caller then it is the earpiece speaker. Got to ebay and buy a kit with the part, and tools. SHouldnt cost more than about 4$ us. come back to this site and you will find a manual on how to replace the part. pretty easy, took about 30 min
Hey Will thanks for the response, i have already tried every type of connection for phoning including a Bluetooth connection in a car and it still has the same issues
Brad,
0
Score
Avatar
Craig
603
Answered
PermalinkHistory
Change the dock connector mic assembly. The apps all work off of the top noise cancelling mic and the calls work off the bottom mic on dock connector. Phone may be stuck in headphone mode.
Edited by: Craig ( )
0
Score
Avatar
asan azad
Answered
PermalinkHistory
reset the settings ... worked for me ... hope it helps
0
Score
Avatar
younes
Answered
PermalinkHistory
hi guys i have the same problem but the funny things is when i used skype or viber or any apps they work fine bur when i try to make call from my sim card i couldtn hear anything please help please
Yes this was the case for me, it is because there is two different microphones in the iPhone 4. One just for calls that has noise cancellation capabilities and the other for voice memos and other apps! Still not found a solution, i believe it is because my motherboard was slightly chipped at the top
Brad,
Add Your Answer
