I actually hard bricked my device Where can I get it done corrected
In order to remove some restrictions on the device , I just mistakenly hardbricked the device with a custom ROM of some other device . If you can then please help me get out of here
1 Comment
@ashusharma78368 Have you tried flashing the stock ROM with Samsung Odin?
by
Add a comment
1 Answer
Chosen Solution
Hello there,
Download stock firmware from sammobile and flash everything again in Odin. It needs to fix the brick.
Good Luck!
2 Comments:
Thanks for the reply . But I have tried everything. The device is just stuck at TWRP logo blinking and not entering into download mode , fastboot mode or recovery mode even. So it's hard to run odin or flash the ROM. If you know further please reply and thanks again 🙏🏻
by
Are you trying to boot in download mode with original charging cable connected to PC?
1. Turn off the phone.
2. Connect the phone with the charging cable to the PC and immediately press the required buttons to boot in download mode. Try several times if need.
by
Add a comment
Add your answer
Ashu Sharma will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 7
All Time: 97
