Repair guides and support for SD, miniSD and microSD memory cards used in tablets, phones and cameras.
36 Questions View all
when I insert it in the Device, I read "cannot read the SD"
Hi, I just tried and after the restoring of the 2 images the SD it's OK. But when I insert it in the Device, i read "cannot read the SD".
I repeated all the steps several times, but always with the same result...
Any suggestion? Thanks
Mitsubishi MMCS NR-242 Map Data Card Update (WinHex Image, European and Russain locale)
Score 1
1 Comment:
@adsroomser25355 Did you use a 16GB SanDisk Ultra SDHC card for the update? Have you tried following steps 11-13?
by
Add a comment
When connected through USB, your SD card may not be detected by your PC for a number of reasons:
Your SD card can be defective or damaged, which would make it impossible for your PC to recognize it. Check a different SD card to determine if the issue still exists.
Connection problems: Verify that the USB cord is functioning properly and that your phone and PC are properly connected. To see if the issue is fixed, try an alternative USB cable.
Driver problems: The SD card may not be identified if your PC does not have the required drivers installed for it to recognize your phone. Attempt to obtain and install the most recent drivers for your phone from the maker's website.
Incorrect settings: Check the settings on your phone to ensure that it is set to transfer files and that the SD card is not being used as internal storage.
Outdated software: Make sure that both your phone and PC have the latest software updates installed, as outdated software can cause compatibility issues.
If none of the above solutions work, it may be helpful to consult with a professional or contact the manufacturer for further assistance.
Add a comment
Bonjour,
Problème résolu en effaçant tout bêtement la participation à l’aide de l’outil Windows.
Insertion de la carte dans le pc, utilisation de l’outils Windows pour supprimer la partition présente sur la carte sd, utilisation de l’outil prévue dans le tuto et c’est tout bon.
Cela fonctionne sans problème sur le véhicule depuis.
Cordialement.
Add a comment
Add your answer
AdsRoom Service srl will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 42
