Released November 2016, the PS4 Pro features upgraded hardware for 4K gaming and improved PSVR performance.
389 Questions View all
Why is my ps4 pro fan very loud?
Hi.So I owned a ps4 pro for about 5 years.I have never changed anything or send it in for repair.I deep cleaned my console and the heatsink but still the same.I notice that even if it is in the menu the psu gets a little hot and the hard drive area also seems hotter.Let me know what I should do please.
Score 1
Add a comment
1 Answer
Chosen Solution
You deep cleaned it, did you replace the thermal paste? If you did, what did you use? If not, I would recommend doing so. Kryonaut Thermal Grizzly, Noctua NT-H1, or Arctic MX-4 would all be a good option to use. Also check the thermal pads on the ram and mosfets/etc. If they are try, cracked, flaking, or covered in dust or debris, replace them. I think they need 1.5mm thickness but I'm not 100% sure off the top of my head.
Score 2
6 Comments:
No I didn't take the motherboard out.But I don't think that's the problem because the psu and the hdd area gets hot.Not the center
by
@evimatz You said you cleaned out the fan. Did you clean out the PSU? Dust can build up in those and they need to breathe.
Also, I would still recommend changing the thermal paste and checking the pads anyway. The shelf life on stock thermal paste is 3-6 years before depreciation sets in, depending on device usage, so if it has never been changed it is likely due or overdue.
by
Ok ill try it
Yes I cleaned the psu
by
Oops I took the heatsink out and it was clogged.Thanks for helping me choose the thermal paste
by
@evimatz Glad it could help, and thank you for coming back and updating. It helps other people who may have a similar issue in the future. If they google the terms and find this thread, they now have positive confirmation that this is a solution for the problem. :)
by
Show 1 more comment
Add a comment
Add your answer
Evi Matz will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 13
Past 30 Days: 44
All Time: 311
