Repair your Dyson V6 Animal vacuum with a part replacement guide.
3 Questions View all
Flashing red light when trying to use my vacuum
I am getting a steady interval flashing red light when trying to use my vacuum. (I stopped counting at 25 consecutive flashes.)
It properly charged during its last charge but will not function. My instinct tells me this may be a battery issue as I'm sure it's reached its maximum charge/disbursement lifetime.
I also notice that if I plug it in to charge now, I get the same flashing red light. It has not been dropped or anything else.
Is a battery the correct component I should be eyeballing?
Many thanks!
Kim K.
Add a comment
1 Answer
Chosen Solution
If the LED indicator on your Dyson V6 flashes red when the vacuum is on or charging, it means the battery is faulty and the vacuum cannot be powered on or charged. The battery will need to be changed to address the flashing red light issue.
You can try resetting the battery by unplugging the charger from the wall, plugging it back in, connecting it to the vacuum, pulling the trigger and holding it for 20 seconds, and then letting go of the trigger.
Otherwise, here's the battery you'll need: https://www.dyson.com/support/journey/to...
Score 1
1 Comment:
The light is blue on the charger. As he said, when using the vacuum, it turns red and flashes. In other words, it's not the battery.
by
Add a comment
Add your answer
Kim K. will be eternally grateful.
Past 24 Hours: 39
Past 7 Days: 230
Past 30 Days: 1,047
All Time: 7,784
