Model A1311 / Mid 2010 / 3.06 & 3.2 GHz Core i3 or 3.6 GHz Core i5 Processor
342 Questions View all
strange crackling noises coming from inside
so i got an iMac that someone gave me, and sometimes it makes weird crackling noises they seem to be coming from inside of it, and it does them only when powered on, it's not that loud and it seems to be coming from behind the screen mostly where the psu is located, but i'm not sure...
§the mac works perfectly though, no flickers, no sudden shutdowns, no weird smells, i heard that it could be an audio issue, also that a capacitor on the psu can be failing and cause the problem, as of the location of the crackling noises the psu is the most likely thing.
but will i have problems in the future if i keep using it like it dying on me randomly? i had a psu from a 2006 imac explode on me once and i don't want it to happen again on my 2010, i do have another psu from a 21.5'' 2009 imac of the same size, last time i tested it it worked, so is it compatible with the 2010? also if the current psu dies will it just die or damage other parts of the system?
Score 1
Add a comment
1 Answer
Most Helpful Answer
@hazel14847 without hearing it or seeing it and going by your description, this sounds like an issue with the PSU. Probably bad (aging) capacitors. You could consider replacing the PSU or recapping it, since it still functions.
If the caps do "pop", the damage will remain isolated to the PSU.
Score 1
2 Comments:
okay thanks! is the 2009 imac psu compatible with my 2010? (both 21.5'')
by
Add a comment
Add your answer
Hazel will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 2
Past 30 Days: 2
All Time: 31
