Release Date: January 5, 2022.
3 Questions View all
meu pc apos mudanca pasta termica nao arranca
mudei a massa termica do pc removendo a bateria e desde enetao nao foncionou mais. o que podera ser?
Google translate:
my pc after changing thermal paste does not start
I changed the thermal mass of the pc by removing the battery and since then it has not worked anymore. what could it be?
Add a comment
1 Answer
@filipemoutinho since it worked before and stopped working after you changed the thermal paste, make sure that everything is properly connected. Double check each and every connector. Make sure that they are properly seated. Use a multimeter and measure to see if your computer gets power from the DC in Jack.
Translation
@filipemoutinho uma vez que funcionava antes e deixou de funcionar depois de mudares a pasta térmica, certifica-te de que tudo está corretamente ligado. Verifique novamente cada um dos conectores. Certifique-se de que estão corretamente encaixados. Usa um multímetro e mede se o teu computador recebe energia do conetor DC in.
Add a comment
Add your answer
Filipe Moutinho will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 6
All Time: 64
