Repair guides and disassembly information for the 14-inch MacBook Pro released in October of 2021, featuring Apple-designed M1 Pro and M1 Max SoCs. Model A2442.
73 Questions View all
Why my speaker making crackling/rattling sound
Why my speaker making crackling/rattling sound on right side? Especially on low frequency sound. I search all over internet. Not even one method work for me. Have been tried to adjust L & R balance, left side is fine. FYI, I'm not cranking up the volume to the max. Only using on 50-70% of volume. Is there any other method that can help me without disassembly?
Add a comment
1 Answer
Most Helpful Answer
Sounds like you either have a blown right speaker, or some debris has worked itself into the computer and his resting on the speaker causing a rattling noise. In either case, you'll probably need to open it up to inspect the speaker. If you can't find anything loose or any debris then you may need to replace the speaker. You should also check with Apple to see if you have any Apple Care coverage. Good luck!
Score 1
Add a comment
Add your answer
itsahmad will be eternally grateful.
Past 24 Hours: 3
Past 7 Days: 20
Past 30 Days: 116
All Time: 771
