Released September 24th, Apple's 2021 flagship smartphone features a 6.1" ProMotion OLED display, a new triple-lens rear camera system, and 5G. Successor to the iPhone 12 Pro.
59 Questions View all
Can I replace the back glass with using the existing camera glass
My IPhone recently broke on the back and it is not bad at all only a minor crack at the edge on left bottom. But I want to replace the back can I replace without removing the back camera glass. I found some cheap ones on Amazon but they have larger camera holes which I don’t want to use. Thanks for the help
Add a comment
1 Answer
Most Helpful Answer
larger camera hole glass is the one to use if you don't want to remove the camera lens, if your using heat to remove the old glass only use around 240c as it has less chance of damage to other parts
Score 1
Add a comment
Add your answer
Var27 will be eternally grateful.
Past 24 Hours: 3
Past 7 Days: 5
Past 30 Days: 13
All Time: 68
