Released in March 2019.
3 Questions View all
Laptop Overheating At Very High Temperatures
I have an 225-G7 from HP. I use it as a proxmox server. There is really not a lot of load on it. It just has 3 LXC containers. For some reason it is overheating a LOT and the fan goes crazy. I have tried everything. I have cleaned the cpu and the cooler and put new thermal paste, I have clean the insides with compressed air, I have even disassembled the fan itself and cleaned it. What else could I possibly do? Like, right now as I am typing this, the fan suddenly ramped up and it sounds like there is a jet in my room. Any ideas???
(Images of load (which is really not much) and graph of temps over about 11 hours below)
Score 1
3 Comments
Do you have access to a laser or IR thermometer to go over it and find out exactly where it's getting hot the most? Is it running the original fan? Loose fan blades?
by
@automotive Unfortunately not. That would be really helpfull, but I don't have a thermal camera or an ir thermometer or whatever.
by
@automotive "Loose fan blades" Possibly, but I opened it very recently and I touched the fan and I think the blades where firmly attached on there so I don't think they are loose. I didn't really check though.
by
Add a comment
1 Answer
Chosen Solution
@sthivaios looking at your temp graph it really does not show that it is overheating a lot. Your average and your T max do not look bad at all.There are times when it ramps up but I do not see anything leading me to believe that there are major issues. I would start by replacing the fan. They are really not meant to be taken apart. Start with that and also let us know the ambient temp. That may be a contributing factor. Last but not least, consider checking and updating the BIOS.
Score 2
11 Comments:
Will try :)
I can't really get a fan right now but as soon as I get one I will do that.
Also, the weird thing is that I used it like that (as a server) for quite a lot of time and it didn't do that. I wasn't monitoring the temps back then, but I had never heard the fan sound like a jet like it is doing right now. After using it for a server, i put ubuntu desktop on it and then reinstalled proxmox (the installation I have right now). Then the issues started. I took the fan apart after it started going crazy so I doubt that opening the fan damanged something but I will check it. (Btw, it is literally so loud right now, it is louder than the dang AC when it is on "turbo" mode)
by
(correction) *damaged
by
@sthivaios I totally get that and no, I did not mean to imply that you damaged the fan. I wonder if this is not a software issue with the monitoring and then the ramping up of the fan. The temps are really not bad and should not require your fan to go into "maximum Overdrive"
by
@oldturkey03 Yeah I think that it is full overdrive rn. It sounds so loud. But like, when I bring my hand close, it is not like spewing hot air like it is an oven or anything. Could be a software issue, i'm not sure. Maybe proxmox is causing it to do that? I don't know why it would do that but it is possible. There is one major difference : the other time i installed proxmox, it was proxmox 7.4 (i think - definitely 7.x just not sure if it was .4) and it wasn't doing that. Now I am running proxmox 8.0. I think it is very unlikely but isn't it possible that there is something going on with the new proxmox??
by
@sthivaios it could be. I would definitely look at the software end for this issue.
by
Show 6 more comments
Add a comment
Add your answer
Stratos Thivaios will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 11
All Time: 97
