The HP Compaq 8200 Elite is a small form-factor workstation-class desktop PC aimed at higher-end office and design work. It has a fairly repairable design with emphasis on allowing technicians to quickly swap out drives and cards.
20 Questions View all
My computer is not displaying on the screen memory stick is ok
How do i troubleshot this problem
Update (06/27/23)
Tried the prossesor it is heating up, when i remove it it is beeping but when i remove the memory stick it is not beeping. I dont want to decreare the motherboard is not ok but i rearly want your troubleshooting options. Please assist
Score 1
2 Comments:
@peternjogukuria "prossesor it is heating up..." hot hot does it get and do you have a fan in your system? does the fan work? "when i remove it it is beeping" why would you remove it and yes, it is supposed to beep. "when i remove the memory stick it is not beeping" how many memory sticks does your computer have? What type of memory? Now, the most important part. With your processor properly connected and your RAM installed, what happens when you turn the computer on?
by
RAM may be damaged. What is the beep code when powering it up? (the number/sequence of beeps)
by
Add a comment
Not open computer I kown his started
Add a comment
My cpu in not screening on monitor and beeping sometime then turning fan
Add a comment
Add your answer
Peter njogu kuria will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 1
All Time: 206
