Released September 20, Apple's mainstream 2019 iPhone comes with a 6.1" LCD touchscreen, dual cameras, and six available colors. Successor to the iPhone XR.
481 Questions View all
Broke a Customers Face ID. Camera Related? Or? iPhone 11
Hello,
I had some technical difficulties with my first spot welding battery. Long story short i needed to remove the new battery and want to be carefull not to bend it..
I guess i used too much rubbing alcohol...
Alcohol got into the main back camera and it looks all wierd...
Onto the Face ID:
The front camera was having trouble focusing, i cleaned it really good in alcohol and seems to focus ok now.
Face ID Says Move phone higher or move phone Lower.. Then eventually it gives the message "face id is not available"
Because of the issue with the rubbing alcohol i am guess/hopping the issue is with front camera.
Question: Can the camera itself cause face ID not to work?
Question: Can the dot projector be damaged from rubbing alcohol?
Does anyone have experience with either of these programmers? Does the face id tester just test, or can it copy to a new dot projector?
https://www.mobilesentrix.ca/id-face-dot...
https://www.mobilesentrix.ca/clone-dz03-...
Thanks a bunch in advance,
Kevin
Score 1
Add a comment
Chosen Solution
I never ended up Fixing the Face ID...
I went staight to trying to program the dot projector with a Icopy face id board and new flex cable.
it didnt work. I read comments after the fact that i should have tried mutliple flex cables, because sometimes they dont work.
After that i figured i woud try to transfer the dot projector chip onto a new flex, but that was too hard of a job, i cracked the dot projector chip housing trying to remove it from the housing....
1 Comment:
found this...
See at 50 Seconds...
https://youtu.be/-fLJDg9QRP0?si=_LTJwXwr...
After scanning if the
"I2C" says something like "Breaking" then it cannot be activated
and if
"IC Data": "Normal"
"Result": "Luminecence Anomalies"
Then it cannot be activated
BUt if "IC Data" Says "Fusing then it can work?
by
Add a comment
Wow this was an interesting find. THe dot projetor can get out of allignment and cause too high or low issue...
https://youtu.be/chAhHRtjoi8
https://www.mobilesentrix.ca/dot-project...
__________________________________
https://youtu.be/vwYpSOYqoig
Icopy Plus Face ID Repair Board.
https://youtu.be/8VOAMFGIeqI
CLONE-DZ03 FACE ID Repair Tool
"Face Id Repair with Tag on Flex and Programming only? (No Soldering Required!!!)"
https://youtu.be/OnFCp9ttvTk
Add a comment
https://logi.wiki/index.php/iPhone_Face_...
https://logi.wiki/index.php/Face_ID_Trou...
https://logi.wiki/index.php/Face_ID_Prec...
Add a comment
Add your answer
Kevin W will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 4
Past 30 Days: 19
All Time: 148
