Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 8, 16 or 32 GB capacity / black or white plastic back.
1502 Questions View all
Ribbon cable 7 won't fit
Hi,
I replaced the volumebuttons, everything went smoothly, but when I reassembled everything back, the ribbon cable no.7 simply won't snap back it. Cable 6 with the same plug is no problem at all, I fiddled around for 25 min and I never used any force, still no success... Looks a bit like the connector on the logicboard is a bit deformed, but I don't know for sure...any ideas?
If I am right, ribbon cable 7 is for the antenna? I taped it, I got reception, but it is not really stable.
Score -1
Add a comment
1 Answer
Chosen Solution
Yes, that is for reception. You may have just bent it out of shape enough that it won't pop back in again. You have to use a microscope or magnifying glass to look at it and with some tweezers/forceps manipulate it into shape. Worse case is, you need it replaced. That is something more challenging. Requires desoldering and soldering of a new one on.
Add a comment
Add your answer
edwood110 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 2,060
