0
Score
Avatar
jmorgan76
11
Asked
How to solder battery connector fact to logic board?
History
Damaging the battery conector on the logic board seems to be a common error people make when taking apart a iPod classic for the first time.
Has anyone successfully reattached this to the logic board? can it be done? If so how? Where can I find someone to solder it for me?
I know I can buy a new one but I'd like to save some money.
Edited by
Post Answer
2
Score
Avatar
oldturkey03
59.5k
Answered
Accepted Answer
PermalinkHistory
It is a tricky repair since the connector is an SMD part. It is soldered on top of the board. This requires some special skills, but it is doable. Check this video for more insight. You can get the part from places like this. If you are not sure about your skills of getting it done, you might just want to try a TV repair shop and see if they can do it for you. If you have the part and the board out of your ipod, it should be straight forward and not to expensive. Make sure that the cost for the part and the repair do not exceed that cost for a new logic board, so I would think no more than $50 together. Hope this helps, good luck.
I took it to a pro and he said that part of the board pulled up with the connector. He said it could be repaired but since iPods are so tightly put together the repair would probably be damaged during reassembly. I ordered another board on eBay. Hopefully it works after investing in a new board.
jmorgan76,
jmorgan76, thank you for accepting my answer. I do know that this happens very frequently, have had a lot of boards with the same thing in my collection. Anyhow, I am convinced that with a new board your iPod will be working just as it should. Good Luck to you.
oldturkey03,
Add Your Answer
