Right click is no longer working on Logitech G Pro Superlight
After my mouse fell off a table the right click is no longer working. Left click is working fine
You need probably replace switch D2FC-F-7N(20M) in Right Mouse Button place on this pcb
kThanks Jakub. I have already ordered a couple of huano switches; and I'll test the original ones before replacing; But I have a feeling this is not my issue? My symptoms as explained above are more of an IC with a bad contact.. I will however test the original switches for electrical continuity; and post results.. Just very short in time, hoping to do this within the month ;0)
BTW I have also received a new mouse from Logitech after contacting support.. I must say the experience was outstanding.
Past 24 Hours: 4
Past 7 Days: 32
Past 30 Days: 144
All Time: 2,035
Can you take apart the mouse and upload a picture of the circuit board inside? Adding images to an existing question
by Andrew S
Can you hear or feel the click of the right mouse button?
by Jade
I have the same problem. Left and Right click work/don't work... Switches click and sound as new. It feels like there could be a loose connection of some component solder or ribbon cable plug. Opened the mouse up, inspected ribbon cables and connections; All seems sound, overall look of pcb is sound. Can someone from support step in and give us a probable cause?
by chico_motta
@io93rdv5rxdhh5n
> ...click and sound as new. It feels like there could be a loose...
Not helpful.
> Opened the mouse up, inspected ...
Where's the photo?
You don't make it easy to help.
by Jade
