The PlayStation 3 (or commonly known as the PS3) is the third home computer entertainment system produced by Sony Computer Entertainment, and the successor to the PlayStation 2. It was released November 11, 2006
783 Questions View all
My ps3 wont spin disks. how do I know what to replace?
i got a faulty ps3 for cheap and everything's fine except when i try to play disks. they get accepted and the icon shows up but they wont show up on the ps3. i dont know whether i need to replace the lazer or the motor. any help?
Add a comment
Most Helpful Answer
It's most likely the laser that is faulty but to replace the whole drive is much easier especially if you don't have to much experience. Either way it is a relatively straight forward job, lots of videos online and most likely tutorials on this site. You can buy the drive as a complete kit online, you just need to swap the board at the bottom of your faulty drive to the new drive.
Also to note, if the warranty stickers have been removed then there is the possibility that the drive board I referred to above has already been swapped out and the one installed isn't the original and therefore even if the laser was replaced it all wouldn't play a disc.
Score 1
Add a comment
It maybe that the laser diode has faded and needs replacing, but other methods may get the optical pickup working again. Try removing and replacing the ribbon cable at the optical pickup (laser) end (I've seen this work). Or try adjusting the miniature potentiometer(s) a fraction in either direction and put the dial back to exactly the same position (better still, measure the resistance so you get it precise). Could use a drop of electrical contact cleaner. (I have heard this works but never tried it)
Add a comment
Add your answer
kian hughes will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 4
All Time: 35
