2.3L 4cyl or 3.0L V6, 6th Generation
428 Questions View all
Cranks but won't start
2000 Honda Accord 2.3 cranks but won't start. I have replaced all the common issues ignition switch, ignition coil, etc. It is getting fuel has compression but the spark seems very weak. Tested the voltage to the coil and it is 3.3 volts. Any suggestions on where to go next?
Add a comment
The voltage from the coil seems low. Not much experience with Hondas though. Is that the output voltage or what's coming into it?
1 Comment:
That is voltage to the coil
by
Add a comment
if you haven't done this yet, check your eng, fuse. my car would crank but not start & that was it. it's a 10amp
just now by will
Add a comment
Add your answer
Michael Leonard will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 16
All Time: 228
