Restarting every three minutes due to panicString
Hi, im getting random restarts, i have this log, thanks in advance :)
Hi @addeboi,
I'm going to have to disagree with @tojaert in his analysis of your issue. Mic1 is located on the charge port flex cable, but the one you're having the problem with is mic2, the one that's used when recording videos. That microphone is located on the power button flex cable. Unfortunately, most of my usual sources including iFixit do not have a guide to replacing that part, but I did find a Spanish site that has just what you need to do that repair.
Manuales / Apple iPhone 11 / Power button, flash and top microphone
You can find the part on most of the big retail sites like Amazon, eBay and AliExpress. Here's an example from Amazon.
If you're interested in more information regarding analyzing panic logs, see @flannelist's excellent Wiki article on the subject.
Thank you for yore answer!
Since I live in Sweden the outlet and voltage may differ, is this product from Amazon compatible with my device?
@addeboi Yes, it is. All iPhones charge via USB which is the same no matter where in the world you are, so no worries on that account. It doesn't matter what power is going into the charger; what matters is the 5 volts coming out and going to the phone (that may vary depending on fast charging capabilities of the phone and the charger, but they all start at 5 volts).
hello there,
I thought I wrote everything about the panic log in the iPhone and iPad. Details you can be found on my blog (address in the description "about me"). Anyway, your log entry points directly to "userspace watchdog timeout" with "missing sensor: mic2" parameter. That's means damaged DOCK port/ or power&flash ribbon, as a result of laser cutting of the back cover, flooding or impact damage. Buy an original DOCK tape /power flash tape for your model, plug it in and enjoy trouble-free operation of your phone.
Past 24 Hours: 2
Past 7 Days: 9
Past 30 Days: 21
All Time: 228
