This Nintendo DS Lite was released in 2006 as the successor to the Nintendo DS. Getting inside this device is simple, making for easy fixes.
318 Questions View all
Nintendo DS Lite Green Lite, Pop, Won’t power on
So, I just reshelled a Nintendo ds lite that was powering on fine before the re-shelling
Now when I go to power it on, the green light comes on bottom screen flashes for just a second and it shuts off
Not sure what the problem is because I can’t see anything I may have damaged
Add a comment
1 Answer
Hi!
When DS systems turn off with a pop, it usually means that something isn't connected properly. Make sure that all your ribbon cables are seated correctly, especially the one for the top LCD, that one is a pain to put back in correctly.
If reseating all your cables doesn't fix the issue, maybe check the top LCD ribbon, and i mean the whole ribbon, not just the connection. You said you can't see anything that you may have damaged, but it is very easy to damage the ribbon when rolling it and getting it through the hinge.
Add a comment
Add your answer
Dimarnae Deveau will be eternally grateful.
Past 24 Hours: 3
Past 7 Days: 6
Past 30 Days: 17
All Time: 116
