Repair and support for the controllers that shipped with the PS3. Released in November 2007 (Japan only) and 2008 (other countries), the six-axis lithium battery powered controller (CECHZC2) is straightforward to repair.
157 Questions View all
Why is 4 red lights blinking?
I recently took apart my DS3 and put it back together, ever since then I have received 4 flashing red lights everytime i plug it in. It does not give off any lights when unplugged
Edit: I have used the reset button and switched batteries.
Add a comment
1 Answer
Sounds like the board isn't connected to the battery properly and isn't charging. Open it up and check all the connections.
7 Comments:
Hey and thanks for answering! Shouldn't the controller work with unplugged battery whilst connected with usb?
by
@thimstr I don't think so. Usb is purely for charging and not actual power.
by
@strongbow Well, I switched with a brand new battery yesterday and I got the exact same results, sorry for not providing this info firsthand.
by
@thimstr obviously the battery is connected. Have you tested voltage to the battery connector with a multimeter with the cable connected? Check the voltage on the new battery too.
by
@strongbow Thanks for the suggestion, I would have to bring home a multimeter from work, is there anything else I could check in the meanwhile?
by
Show 2 more comments
Add a comment
Add your answer
Thim Strömberg will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 22
Past 30 Days: 70
All Time: 558
