Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White. This page aims to help users troubleshoot, fix, and seek help for the iPhone 4.
2375 Questions View all
Can I Replace the Digitizer without Replaceing the LCD?
I am trying to repair a black AT&T iPhone 4.
The front screen & rear glass panel are both shattered.
I know (thanks to iFixit!) how to replace the rear panel, but I'm stuck on the front panel: I've heard that it isn't possible to simply replace the digitizer on the iPhone 4 (because the LCD is permanently attached to the digitizer) but that you have to replace the entire display assembly. Online I have found iPhone 4 GSM digitizers for $30+, but the iPhone 4 GSM display assembly is $120. Can I simply replace the digitizer, or do I have to replace the whole display assembly?
Score -1
Add a comment
1 Answer
Chosen Solution
It is possible; However, you won't be happy with yourself. The reason is that the LCD is so thin that removing it without breaking it takes a ton of time and patience. Not to mention once it is reassembled it never looks quite the same since it won't line up properly with the frame.
Score 1
1 Comment:
Definitely agree with that. Replacing the whole assembly is more expensive, but the only way to go to ensure a successful repair
by
Add a comment
Add your answer
Black0ps will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 1
All Time: 4,122
