Released on February 22, 2023, the PlayStation VR 2 is the second reality headset developed by Sony and designed for the PlayStation 5.
10 Questions View all
Can you use Polywatch Plastic to fix Lense Scratches?
Curious as a glasses user because it is bound to happen eventually that the lenses get a scratch on them on accident.
In the past, none of these scratches are very deep but I'm curious because I've heard for other headsets you could use it to remove minor scratches like those that might occur from glasses scratching against the lenses.
Score 2
Add a comment
1 Answer
Chosen Solution
Hi
I really wouldn’t use scratch remover on any type of display that uses a colour display,iv tried in on a couple different displays that were broken just to see what happened and on every occasion it made the displays much much worse
When polishing all you are doing is removing a layer,displays are already very polished so that light won’t refract and bounce all over the place,from my experience the polish will add LOADS of smaller scratches that will result in a image that isn’t clear at all due to millions of little rainbow lines(scratches with light refracting through them)
So I would order a new lens if they are available ,of course that’s if it is big enough to be worth it:-)
Hopefully this helps
Any questions please ask
Score 3
1 Comment:
What OP is talking about are the lens and YES it does work
by
Add a comment
Add your answer
Joshua Haas will be eternally grateful.
Past 24 Hours: 4
Past 7 Days: 9
Past 30 Days: 51
All Time: 1,266
