Repair guides and support for your Philips TV.
251 Questions View all
Some straight lines are apearing and darken image
i've got this problem that when i turn on the tv it have those straight lines apearing like the screen is brocken and its darken in some places but after a while, like if it was after warming up, the tv is fully normal, i dont realy know what can be happening, i have some images that can show what's happening, any ideas?
Update (02/23/2023)
hello friend, i posted the images as you asked, i believe the model of my tv is the 42PFL5603D/12
Score 1
1 Comment
@linkoutsider post those pictures with your QUESTION. Edit the question and insert the images. Adding images to an existing question
What is the exact model number for your TV?
by
Add a comment
1 Answer
Most Helpful Answer
@linkoutsider under any other circumstance I would have said this is a backlight issue. Until I've seen the lack of signal on the right side of the screen. This looks like a bad (failed signal) of the panel. You can try and check the LVDS cables and make sure they are not torn, corroded or otherwise damaged. Ultimately, it does look like a bad panel.
Score 1
2 Comments:
ooh, i understand, the thing is that after some time it goes full normal you see? but i will check on that and give you some news.
i apreciate your help a lot, thank you.
by
@linkoutsider could be a failed capacitor or similar component. Get a can of freeze spray and spray it on the components, one ar at a time. If the picture returns to normal, you at least have the general area where and what to check.
by
Add a comment
Add your answer
Sh0uz3r will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 8
All Time: 79
