Nintendo's first 3DS handheld device released February 2011, identified by model number CTR-001.
459 Questions View all
Need help fixing 3DS that only powers on when plugged in.
Hi,
I have an original 3DS that only powers on when plugged in to the charger. (It charges fine.) However, I can disconnect it from the charger immediately after it boots up and it works fine with just the battery. I have changed the battery and it turned on without the charger a couple of times then went back to only turning on when plugged in. I have tested the batteries with other 3DSs and they work great. I have taken the 3DS completely apart and cleaned it. I did notice a little rust underneath the SD reader. I cleaned it up really good and the SD reader reads the SD just fine. I even tried removing the SD card and putting it back in but this does not work. I tried without the SD card, this does not help. I also removed the battery and then put it back in, did not work.
I have fixed, repaired, and taken apart multiple 3DSs and DSs. I have even done some basic (I mean basic) soldering. Cannot seem to figure this one out. Help please!
Add a comment
1 Answer
Chosen Solution
Well, I think I fixed it. I did some deep cleaning (on both sides of the motherboard) within the charging port and the battery terminal with Isopropyl alcohol. I soaked those areas and scrubbed where I could. I dried it with compressed air sprayer. I turned it on with just the battery and it booted to the power off screen and then it turned off. I plugged in the charger and turned it on and it worked fine. So I let it sit over night. In the morning with just the battery I turned it on. It worked! We will see how long it lasts. But I'm hopeful.
Add a comment
Add your answer
TeamBZ will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 9
All Time: 220
