Repair guides and support for all-in-one washer and dryer assemblies as well as stacked units.
140 Questions View all
Plastic particles in wash
Have seen plastic particles in wash. Looks like the drum is rubbing on the outer drum?
The spindle also makes a rubbing/grainy noise when you spin it, & it will move both ways.
Does this mean the spindle needs replaced? & what about the drum issue?
2 Comments:
Hi @amaruno2006,
What is the make and model number of the combo unit?
by
@jayeff
Model: GUD24ESSM1WW
Serial: HM062116C
by
Add a comment
1 Answer
Hi @amaruno2006
Here's the motor drive assembly parts diagram that may help to see what's wrong and with the tub rubbing on the drum check if the suspension rods (#401 & #402) are OK.
If you find a faulty part, scroll down and click on the part in the link to find the manufacturer's part number and use that number to find other suppliers that may suit you better.
GE Rod Assembly 24" - WH16X27182 Image
Product
$13.99
GE Rod Assembly 24" - WH16X27181 Image
Product
$14.99
Add a comment
Add your answer
Amber Marunowski will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 13
All Time: 31
