Part of Google's third generation of Pixel phones, the 3a is a budget-minded option with the same camera as Google's flagships. Available in Clearly White, Just Black, or Purple-ish. Released May 2019.
70 Questions View all
Screen is black after replacement
I followed the iFixit guide to replace the screen. Initially the phone battery was fully drained. I removed the old broken display, connected the new one, charged the phone a little to test if the new screen is working and glued it. However, I didn't to a good job with the glueing and decided to take the screen off and reglue it without disconnecting from the motherboard. I didn't remove the battery either which was charged at about 20% at that point.
Now the screen is black and I can't see any apparent damage to the connector or pins.
Add a comment
1 Answer
you may have either
1 damaged the screen cables during the process of taking the screen off again, or
2 blown the display out because you didn't disconnect the battery the 2nd time
Add a comment
Add your answer
Bob will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 13
All Time: 78
