Repair guides and support for desktop computers produced by Asus including towers and all-in-one display PCs.
144 Questions View all
Asus P7H55-M LE BIOS Settings
Hello
I have an Asus P7H55-M LE Motherboard and I can't install Windows 7. The installation process stops during the installation. I think the problem is solved by some of the BIOS settings, but I don't know which setting to change. If anyone knows what BIOS setting I have to change, please reply.
Thanks
2 Comments:
Do any error messages appear when the installation stops?
Have you had this machine working before and if yes what Operating System was it using?
Is BIOS upgraded to version 0801?
Is SATA configuration set to AHCI (page 2-9 in manual)?
https://www.asus.com/us/supportonly/p7h5...
Why do you think it is a BIOS setting?
by
Thank you for reply
No messages appear, just stops the installation
Yes,. the machine was running Windows 7 before.
I don't know if the BIOS has been upgraded to version 0801, besides I don't know how to upgrade the BIOS
I have configured the SATA and in AHCI mode but it did not solve the problem
What leads me to believe that the problem is solved by some BIOS setting is that when I bought it (about ten years ago), the technician/seller, before installing Windows 7, had made some settings in the BIOS and then Windows 7 installed without problem. But after all these years I don't remember what settings he made in the BIOS.
by
Add a comment
1 Answer
First BIOS download:
https://www.asus.com/supportonly/p7h55m_...
ASUS P7H55-M LE manual
Section 2.1.2 will explain how to update the BIOS using ASUS EZ Flash 2 and a USB flash drive. EZ Flash 2 will also show you, on the left side, what your current BIOS version is.
Add a comment
Add your answer
freeman will be eternally grateful.
Past 24 Hours: 3
Past 7 Days: 3
Past 30 Days: 14
All Time: 292
